Salta al contenuto principale
Dell Precision M6800 Keyboard Replacement
Cosa ti serve
  1. Dell Precision M6800 Keyboard Replacement, Dell Precision M6800: passo 1, immagine 1 di 1
    • Replacing Dell Precision M6800's keyboard
  2. Dell Precision M6800 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Precision M6800 Keyboard Replacement: passo 2, immagine 2 di 2
    • Before any repair, you should remove battery
  3. Dell Precision M6800 Keyboard Replacement: passo 3, immagine 1 di 1
    • Pry and remove the frame around keyboard (it's a bit lighter than rest of casing).
  4. Dell Precision M6800 Keyboard Replacement: passo 4, immagine 1 di 1
    • Unscrew 4 fastening screws which are at bottom of keyboard
  5. Dell Precision M6800 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Precision M6800 Keyboard Replacement: passo 5, immagine 2 di 2
    • Pry out four hooks which are on the sides of keyboard (two per one site)
    • Be carefull to not break of hooks - use constant force and do it slowly
  6. Dell Precision M6800 Keyboard Replacement: passo 6, immagine 1 di 2 Dell Precision M6800 Keyboard Replacement: passo 6, immagine 2 di 2
    • Pick up a little keyboard and eject it. Than pick up harder but DO NOT take it out
    • DO NOT take keyboard out, it is connect to the motherboard and you must unhook it in next step
  7. Dell Precision M6800 Keyboard Replacement: passo 7, immagine 1 di 2 Dell Precision M6800 Keyboard Replacement: passo 7, immagine 2 di 2
    • Pry up the white part of connector (constant for both sides) and eject connecting flex
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
Great job, thank you
kali1902 - Replica
Broke off the stupid white clip holding the connector in place go to h ell
Stan B - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,340
