Salta al contenuto principale
Dell Precision M6700 Hard Drive Replacement
Cosa ti serve
  1. Dell Precision M6700 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Dell Precision M6700 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M6700 Hard Drive Replacement, Base Cover: passo 2, immagine 1 di 2 Dell Precision M6700 Hard Drive Replacement, Base Cover: passo 2, immagine 2 di 2
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer
  3. Dell Precision M6700 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Remove the screws that secure the primary hard drive to the computer. Slide the primary hard -drive latch to the unlock position and pull out the hard drive from the computer.
  4. Dell Precision M6700 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
  5. Dell Precision M6700 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the screw that secure that secondary hard drive in place.
    • Pull the tab upward and remove the secondary hard drive from the computer.
  6. Dell Precision M6700 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the screw that secure secondary hard drive to the bracket.
    • Remove the secondary hard drive from the bracket.
Conclusione
Altre 4 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
45.058 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,887
