Salta al contenuto principale
Dell Precision M6600 RAM Replacement
Cosa ti serve
  1. Dell Precision M6600 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 RAM Replacement, RAM: passo 2, immagine 1 di 2 Dell Precision M6600 RAM Replacement, RAM: passo 2, immagine 2 di 2
    • There are two 1.5mm screws that will be taken off using a Phillips #00 screw driver.
  3. Dell Precision M6600 RAM Replacement: passo 3, immagine 1 di 2 Dell Precision M6600 RAM Replacement: passo 3, immagine 2 di 2
    • The RAM is held in place by two prongs. By pulling the two prongs lightly away from the chip the RAM is able to be pulled out.
Conclusione
Un commento
You forgot to show the two more RAM slots under the keyboard.
Xerkies - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,055
