Salta al contenuto principale
Dell Precision M6600 Hard Drive Replacement
Cosa ti serve
  1. Dell Precision M6600 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: passo 2, immagine 1 di 2 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: passo 2, immagine 2 di 2
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: passo 3, immagine 1 di 2 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: passo 3, immagine 2 di 2
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
  4. Dell Precision M6600 Hard Drive Replacement: passo 4, immagine 1 di 1
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
Conclusione
Altre 4 persone hanno completato questa guida.
Un commento
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,670
