Salta al contenuto principale
Dell Precision M6400 Memory Module Replacement
Cosa ti serve
  1. Dell Precision M6400 Memory Module Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Memory Module Replacement, Base Cover: passo 2, immagine 1 di 1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Memory Module Replacement, LED Cover: passo 3, immagine 1 di 1
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
  4. Dell Precision M6400 Memory Module Replacement, KeyBoard: passo 4, immagine 1 di 1
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
  5. Dell Precision M6400 Memory Module Replacement, Memory Module: passo 5, immagine 1 di 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Conclusione
Johnathan Hammond
Membro da: 02/28/18
45.582 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
44 Membri
1.996 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,473
