Cosa ti serve
Remove the two M2 x 3-mm screws.
Slide the cover toward the front of the computer to release the tabs from the base assembly.
Remove the cover from the base assembly.
Loosen the two captive screws on the HDD1 carrier, and remove the carrier.
Push in, then pull up on the safety loop to remove the cover.
Use the pull tab to disconnect the HDD1 from the connector on the system board, and remove the HDD1 from the computer.
