Parti
Nessuna parte richiesta.
  1. Slide the release latch to unlock the battery. Flip and remove the battery from the computer.
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover. Flip and remove the base cover from the computer.
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Pry up the keyboard trim starting from the top-inner edge. Pry up the bottom edge of the keyboard trim from the top-inner edge.
    • Pry up the keyboard trim starting from the top-inner edge.
    • Pry up the bottom edge of the keyboard trim from the top-inner edge.
  5. Remove the screws that secure the keyboard to the computer. Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over. Disconnect the keyboard-data cable from the system board and remove the keyboard.
    • Remove the screws that secure the keyboard to the computer.
    • Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
    • Disconnect the keyboard-data cable from the system board and remove the keyboard.
  6. Flip Computer To its Back.
    • Flip Computer To its Back.
    • Pry the retention clips away from the memory module until it pops up. Lift up the memory module and remove it from the computer.
  7. Flip the Computer To its Top.
    • Flip the Computer To its Top.
Conclusione
Johnathan Hammond
Membro da: 28/02/2018
35.786 Reputazione
408 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 197
