Salta al contenuto principale
Dell Precision M4400 Hard Drive Replacement
Cosa ti serve
  1. Dell Precision M4400 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
  2. Dell Precision M4400 Hard Drive Replacement, Base Cover: passo 2, immagine 1 di 1
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
  3. Dell Precision M4400 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Dell Precision M4400 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging.
    • Remove the four M3 x 3-mm screws securing the hard drive. These screws are on the bottom of the base cover.
    • NOTE: If the bottom of the base cover is detached from the laptop, the four screws securing the hard drive are marked with an "H".
    • Slide the hard drive out of the computer.
    • Remove the face plate screw and then the face plate from the hard drive.
Conclusione
Johnathan Hammond
Membro da: 02/28/18
45.058 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.984 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,172
