Salta al contenuto principale
Dell Precision M3800 Touch Pad Replacement
Cosa ti serve
  1. Dell Precision M3800 Touch Pad Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Precision M3800 Touch Pad Replacement, Back Cover: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Touch Pad Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Touch Pad Replacement, Battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Touch Pad Replacement, Touch Pad: passo 4, immagine 1 di 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: passo 4, immagine 2 di 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: passo 4, immagine 3 di 3
    • Remove the wire that connects the touch pad with the motherboard with a hooked pry tool (Spudger 3) and by pulling the pull tab to safely remove the wire.
  5. Dell Precision M3800 Touch Pad Replacement: passo 5, immagine 1 di 2 Dell Precision M3800 Touch Pad Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 2mm silver screws.
  6. Dell Precision M3800 Touch Pad Replacement: passo 6, immagine 1 di 1
    • Remove the touch pad from the laptop. If needed, use a prying tool to remove the touch pad.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 987
