Salta al contenuto principale
Dell Precision M3800 Hard Drive Replacement
Guida Archiviata
Questa guida รจ mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Dell Precision M3800 Hard Drive Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Precision M3800 Hard Drive Replacement, Base Cover: passo 1, immagine 2 di 2
    • Turn the system badge fap over and place it on the base cover.
    • Remove the screws that secure the base cover to the computer. Release and remove the base cover from the computer.
    • NOTE: To remove the screws from the base cover, use a T5 Torx screwdriver.
    • Lift up and remove the base cover from the computer.
  2. Dell Precision M3800 Hard Drive Replacement, Battery: passo 2, immagine 1 di 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  3. Dell Precision M3800 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Disconnect the hard-drive cable from the system board [1].
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard drive off the computer [2].
  4. Dell Precision M3800 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Disconnect the hard-drive cable from the hard drive [1].
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard drive off the hard-drive bracket [2].
Conclusione
Altre 3 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
44.953 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.986 Guide realizzate
Un commento
Very helpful guide! Easy to follow and helped me complete this task with ease
Chris Stockton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,541
