Salta al contenuto principale
Dell Precision 7710 Memory Module Replacement
Cosa ti serve
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: passo 1, immagine 1 di 1
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
  2. Dell Precision 7710 Memory Module Replacement, Battery: passo 2, immagine 1 di 1
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: passo 3, immagine 1 di 1
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: passo 4, immagine 1 di 2 Dell Precision 7710 Memory Module Replacement, KeyBoard: passo 4, immagine 2 di 2
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
  5. Dell Precision 7710 Memory Module Replacement: passo 5, immagine 1 di 1
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: passo 6, immagine 1 di 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
  7. Dell Precision 7710 Memory Module Replacement: passo 7, immagine 1 di 1
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
Conclusione
Altre 2 persone hanno completato questa guida.
Johnathan Hammond
Membro da: 02/28/18
46.134 Reputazione
408 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
1.999 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 68
Tutti i Tempi: 2,302
