Salta al contenuto principale
Dell Precision 7560 Screen Replacement
Cosa ti serve
  1. Dell Precision 7560 Screen Replacement, Screen: passo 1, immagine 1 di 3 Dell Precision 7560 Screen Replacement, Screen: passo 1, immagine 2 di 3 Dell Precision 7560 Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: passo 2, immagine 1 di 2 Dell Precision 7560 Screen Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: passo 3, immagine 1 di 3 Dell Precision 7560 Screen Replacement: passo 3, immagine 2 di 3 Dell Precision 7560 Screen Replacement: passo 3, immagine 3 di 3
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Conclusione
Laisha
Membro da: 02/14/23
202 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 63
Tutti i Tempi: 638
