Salta al contenuto principale
Dell Precision 7560 Keyboard Replacement
Cosa ti serve
  1. Dell Precision 7560 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Dell Precision 7560 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Dell Precision 7560 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: passo 2, immagine 1 di 3 Dell Precision 7560 Keyboard Replacement: passo 2, immagine 2 di 3 Dell Precision 7560 Keyboard Replacement: passo 2, immagine 3 di 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: passo 3, immagine 1 di 3 Dell Precision 7560 Keyboard Replacement: passo 3, immagine 2 di 3 Dell Precision 7560 Keyboard Replacement: passo 3, immagine 3 di 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 3 Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, immagine 2 di 3 Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, immagine 3 di 3
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: passo 5, immagine 1 di 3 Dell Precision 7560 Keyboard Replacement: passo 5, immagine 2 di 3 Dell Precision 7560 Keyboard Replacement: passo 5, immagine 3 di 3
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: passo 6, immagine 1 di 3 Dell Precision 7560 Keyboard Replacement: passo 6, immagine 2 di 3 Dell Precision 7560 Keyboard Replacement: passo 6, immagine 3 di 3
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 56
Tutti i Tempi: 738
