Salta al contenuto principale
Dell Precision 5540 Fans Replacement
Cosa ti serve
    • Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
    • Turn off your computer.
    • Disconnect your computer from all the cables.
  1. Dell Precision 5540 Fans Replacement, Remove the base cover screws: passo 2, immagine 1 di 2 Dell Precision 5540 Fans Replacement, Remove the base cover screws: passo 2, immagine 2 di 2
    • Close the display lid and turn the computer over.
    • Remove the M2x3 T5 screws that secure the base cover to the computer.
    • Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
  2. Dell Precision 5540 Fans Replacement, Remove the base cover: passo 3, immagine 1 di 2 Dell Precision 5540 Fans Replacement, Remove the base cover: passo 3, immagine 2 di 2
    • Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
    • Two case latches are approximately here.
  3. Dell Precision 5540 Fans Replacement, Remove battery plug: passo 4, immagine 1 di 1
    • Here.
    • There is a very small amount of space, so I didn't unplugged it fully, just removed from the socket. And made sure that there is no contact.
  4. Dell Precision 5540 Fans Replacement, Remove CPU fan: passo 5, immagine 1 di 1
    • Unplug the fan cord.
    • Note the dot on the fan power socket which mark the upper side.
    • Unscrew M2 screws.
  5. Dell Precision 5540 Fans Replacement, Remove GPU fan: passo 6, immagine 1 di 1
    • Unscrew M2 screws
Conclusione
Nick Panin
Membro da: 05/28/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 373
