Salta al contenuto principale
Dell Precision 5510 RAM Replacement
Cosa ti serve
  1. Dell Precision 5510 RAM Replacement, Base Cover: passo 1, immagine 1 di 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 RAM Replacement: passo 2, immagine 1 di 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 RAM Replacement, RAM: passo 3, immagine 1 di 2 Dell Precision 5510 RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Chose which RAM board you will be replacing on the motherboard.
    • There are two next to each other. One is outlined here.
  4. Dell Precision 5510 RAM Replacement: passo 4, immagine 1 di 1
    • Place fingers on black plastic tabs.
    • Bend the tabs slightly away from the RAM board until the RAM board springs upward.
  5. Dell Precision 5510 RAM Replacement: passo 5, immagine 1 di 1
    • Once the RAM board springs up to an elevated angle as pictured here, gently grab the board.
    • Pull the board (in the direction shown) out of its slot where it is still inserted .
  6. Dell Precision 5510 RAM Replacement: passo 6, immagine 1 di 1
    • If replacing both RAM boards, follow the same process for removal of the other RAM board.
    • The other board is directly to the right of the prior pictured one, and identical. Both are outlined in this picture.
Conclusione
Cooper Zuranski
Membro da: 03/31/22
109 Reputazione
1 Guida realizzata
IUPUI, Team 2-1, Harley Spring 2022 Membro di IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Membri
4 Guide realizzate
1Commento della guida
T4 Torx is listed under required tools, but T5 is the correct size for my 5510.
Chris - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 715
