Salta al contenuto principale
Dell Precision 5510 Fans Replacement
Cosa ti serve
  1. Dell Precision 5510 Fans Replacement, Base Cover: passo 1, immagine 1 di 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Fans Replacement: passo 2, immagine 1 di 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Fans Replacement, Fans: passo 3, immagine 1 di 2 Dell Precision 5510 Fans Replacement, Fans: passo 3, immagine 2 di 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Fans Replacement: passo 4, immagine 1 di 2 Dell Precision 5510 Fans Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Fans Replacement: passo 5, immagine 1 di 2 Dell Precision 5510 Fans Replacement: passo 5, immagine 2 di 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
Conclusione
Amelia Andrews
Membro da: 03/31/22
97 Reputazione
1 Guida realizzata
IUPUI, Team 2-1, Harley Spring 2022 Membro di IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 28
Tutti i Tempi: 490
