Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Prerequisite Only
Parti
Nessuna parte specificata.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  5. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  6. Remove the rubber grommets from the base of the fan. A spudger may be useful. Remove the rubber grommets from the base of the fan. A spudger may be useful.
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
  7. Press on the blue release tab and pull the upper fan out of the computer. Press on the blue release tab and pull the upper fan out of the computer.
    • Press on the blue release tab and pull the upper fan out of the computer.
Conclusione
Wyatt
Membro da: 06/10/2010
751 Reputazione
6 Guide realizzate
Cal Poly, Team 22-4, Maness Fall 2010 Membro di Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,849
