Salta al contenuto principale
Dell Optiplex SX280 RAM Replacement
  1. Dell Optiplex SX280 RAM Replacement, Panel Cover: passo 1, immagine 1 di 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 RAM Replacement: passo 2, immagine 1 di 2 Dell Optiplex SX280 RAM Replacement: passo 2, immagine 2 di 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 RAM Replacement: passo 3, immagine 1 di 2 Dell Optiplex SX280 RAM Replacement: passo 3, immagine 2 di 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 RAM Replacement, RAM: passo 4, immagine 1 di 1
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  5. Dell Optiplex SX280 RAM Replacement: passo 5, immagine 1 di 2 Dell Optiplex SX280 RAM Replacement: passo 5, immagine 2 di 2
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
Conclusione
To reassemble your device, follow these instructions (steps 1-3) in reverse order.
Altre 8 persone hanno completato questa guida.
Wyatt
Membro da: 10/06/10
784 Reputazione
6 Guide realizzate
Cal Poly, Team 22-4, Maness Fall 2010 Membro di Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Membri
26 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 5,511
