Introduzione
Replace the Optical Drive in the computer tower to allow the Optiplex to read CD's and DVD's
Parti
Nessuna parte richiesta.
  1. Position the tower with the Optical Drive facing upward.
    • Position the tower with the Optical Drive facing upward.
  2. Remove the small black screw connecting the Optical Drive to the computer. Remove the small black screw connecting the Optical Drive to the computer.
    • Remove the small black screw connecting the Optical Drive to the computer.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. There is a little blue tab you have to disengage, inside of the case, to be able to pull the DVD drive out. Simply pull it up to release the DVD.
    • There is a little blue tab you have to disengage, inside of the case, to be able to pull the DVD drive out. Simply pull it up to release the DVD.
  5. Press on the drive release button. Press on the drive release button.
    • Press on the drive release button.
  6. Pull Optical Drive out of the computer.
    • Pull Optical Drive out of the computer.
Conclusione
Altre 4 persone hanno completato questa guida.
Tom
Membro da: 04/10/2010
799 Reputazione
7 Guide realizzate
Cal Poly, Team 22-4, Maness Fall 2010 Membro di Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Membri
13 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 4,193
