Introduzione
Remove the Motherboard from the computer.
Cosa ti serve
Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
The RAM are the two green cards in the corner of the computer.
At each end of the card, there are two white clips securing the RAM to the Motherboard.
Altre 11 persone hanno completato questa guida.
2 Commenti
Good job. Thanks for sharing, friend.
Great guide! I got stuck at the Mobo tray, I knew the black screws were involved but couldn't get it with out help. Thanks!
Fans can be removed with board tray, otherwise they're getting pulled off their rubber isolating feet. Once out with the mobo, the fans slide off the board tray with their plastic shoes attached.
