Salta al contenuto principale
Dell Optiplex GX620 CPU Replacement
Cosa ti serve
  1. Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: passo 1, immagine 1 di 2 Dell Optiplex GX620 CPU Replacement, How to unplug and discharge before repair: passo 1, immagine 2 di 2
    • Power down your PC and remove the power cord from the back.
    Chiedi a FixBot
  2. Dell Optiplex GX620 CPU Replacement: passo 2, immagine 1 di 2 Dell Optiplex GX620 CPU Replacement: passo 2, immagine 2 di 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    Chiedi a FixBot
  3. Dell Optiplex GX620 CPU Replacement, Dell Optiplex GX620 Side Panel Disassembly: passo 3, immagine 1 di 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
    Chiedi a FixBot
  4. Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: passo 4, immagine 1 di 3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: passo 4, immagine 2 di 3 Dell Optiplex GX620 CPU Replacement, Now unplug your hard drives power and data cables.: passo 4, immagine 3 di 3
    • Move the cables out of your way.
    • SATA Power
    • SATA Data
    Chiedi a FixBot
  5. Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: passo 5, immagine 1 di 3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: passo 5, immagine 2 di 3 Dell Optiplex GX620 CPU Replacement, Unplug your floppy drive on the motherboard and the drive.: passo 5, immagine 3 di 3
    • Unplug the power cable
    • Unplug the data cable
    Chiedi a FixBot
  6. Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: passo 6, immagine 1 di 2 Dell Optiplex GX620 CPU Replacement, Disconnect CPU fan.: passo 6, immagine 2 di 2
    • Unplug the fan that is on the motherboard.
    Chiedi a FixBot
  7. Dell Optiplex GX620 CPU Replacement: passo 7, immagine 1 di 2 Dell Optiplex GX620 CPU Replacement: passo 7, immagine 2 di 2
    • There is two Phillips #2 screws that need to be removed.
    • The two screws have springs that keep them there.
    Chiedi a FixBot
  8. Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: passo 8, immagine 1 di 3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: passo 8, immagine 2 di 3 Dell Optiplex GX620 CPU Replacement, New it’s time to remove the  heat sink.: passo 8, immagine 3 di 3
    • Lift the heat sink.
    Chiedi a FixBot
  9. Dell Optiplex GX620 CPU Replacement, CPU removal.: passo 9, immagine 1 di 3 Dell Optiplex GX620 CPU Replacement, CPU removal.: passo 9, immagine 2 di 3 Dell Optiplex GX620 CPU Replacement, CPU removal.: passo 9, immagine 3 di 3
    • Push and release tap on it. And then take the CPU out.
    • Remember to put new thermal paste on the CPU.
    Chiedi a FixBot
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 92
Tutti i Tempi: 2,988
