Introduzione
The CMOS battery maintains the time, date, hard disk and other configuration settings in the CMOS memory. When your CMOS battery dies, your system settings will be lost.
  1. Power down your PC and remove the power cord from the back. Power down your PC and remove the power cord from the back.
    • Power down your PC and remove the power cord from the back.
  2. Press and hold the power button for about 10 seconds, then release. This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  4. With the computer standing upright, firmly pull on the tab at the back of the computer.
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  5. Insert a tool beside the battery and gently pry the battery out.
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
Altre 6 persone hanno completato questa guida.
Kristina
Membro da: 03/09/2014
153 Reputation
7 Guide realizzate
Pasco Hernando, Team 5-1, Prince Fall 2014 Membro di Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Membri
15 Guide realizzate
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - Replica
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - Replica
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 164
All Time: 8,864
