Salta al contenuto principale
Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement
  1. Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement, Side Panel: passo 1, immagine 1 di 1
    • Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement: passo 2, immagine 1 di 1
    • Lay the computer on its side; you will see a blue knob.
    • Turn said knob 90 degrees counter clockwise.
  3. Dell Optiplex 745 Ultra Small Form Factor Side Panel Replacement: passo 3, immagine 1 di 1
    • While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
Conclusione
donnavon
Membro da: 09/02/14
707 Reputazione
7 Guide realizzate
Pasco Hernando, Team 1-1, Prince Fall 2014 Membro di Pasco Hernando, Team 1-1, Prince Fall 2014
PHSC-PRINCE-F14S1G1
11 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 821
