Introduzione
You may need to replace the hard drive in your Dell OptiPlex 745 if you've had the computer for several years. If you hear the hard drive clicking or data starts being corrupted, these are signs your hard drive should be replaced soon.
You will need to create a backup before doing anything with the hard drive. Without a backup of your hard drive, all your important data will be lost if it fails. So it's important not to wait before making this replacement. Before you get rid of the drive, it may be a good idea to destroy it so your data can't be recovered by someone else.
In addition, before beginning this repair, be sure to power off your computer and disconnect from the charger.
Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
Find the power and data cables connected to the hard drive, press down on the metal tab and carefully remove them.
