Introduzione
This guide will help you replace the power supply.
Cosa ti serve
Identify the power supply.
Remove the two 9.5 mm Phillips screws on the outside of the case.
Grab the plastic casing and pull out the bundle of cables from the side of the power supply unit.
Push the power supply from the back and lift from the front.
Lift the power supply out of the case.
Altre 16 persone hanno completato questa guida.
