Salta al contenuto principale
Dell Optiplex 745 Small Form Factor Motherboard Replacement
Cosa ti serve
  1. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: passo 1, immagine 1 di 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Opening the case: passo 1, immagine 2 di 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 2, immagine 1 di 2 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 2, immagine 2 di 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: passo 3, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: passo 3, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement, Motherboard: passo 3, immagine 3 di 3
    • Disconnect all of the cords that are connected to the motherboard.
    • Press in the lever on the side of the male end, and then pull out.
    • Pull cord straight out.
    • Disconnect the front plate (USB and audio output) from the motherboard.
    • Some of the cords in the pictures are missing due to the condition of our device when creating this guide.
  4. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 4, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 4, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 4, immagine 3 di 3
    • Remove the graphics card.
    • Lift the blue latch on the fat end of the graphics card.
    • Pull the blue lever on the skinny end of the graphics card toward the power supply.
    • Pull out one end of the card at a time.
  5. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 5, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 5, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 5, immagine 3 di 3
    • Remove the heat sink.
    • Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
  6. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 6, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 6, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove the (5) five 6mm Phillips #2 screws from the motherboard.
    • Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
  7. Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 7, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 7, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Motherboard Replacement: passo 7, immagine 3 di 3
    • Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
    • Pull the end of the motherboard closest to the back of the computer away from the static back plate.
    • Lift this end away and out of the case.
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team S5-G5, Walkup Fall 2017 Membro di USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,740
