Salta al contenuto principale
Dell Optiplex 745 Small Form Factor Graphics Card Replacement
  1. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: passo 1, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: passo 1, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement, Graphics Card: passo 1, immagine 3 di 3
    • Pull the tab on the cover to release the lid.
    • Remove the cover to expose the computer.
  2. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 2, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 2, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 2, immagine 3 di 3
    • The graphics card has a fan built into it and is fasten by two blue clips.
    • Pull up the top blue clip that is above the graphics card while holding the graphics card in place.
  3. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 3, immagine 1 di 3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 3, immagine 2 di 3 Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 3, immagine 3 di 3
    • Below the graphics card, there is a second clip that holds the card in place.
    • With one hand, pull back the clip while lifting the graphics card with the other.
  4. Dell Optiplex 745 Small Form Factor Graphics Card  Replacement: passo 4, immagine 1 di 1
    • Remove the graphics card.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S5-G5, Walkup Fall 2017 Membro di USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Membri
9 Guide realizzate
Un commento
Graphic card modal no please
Mans Manshion - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,414
