Salta al contenuto principale
Dell Optiplex 745 Small Form Factor Audio Components Replacement
Cosa ti serve
  1. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: passo 1, immagine 1 di 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement, Opening the case: passo 1, immagine 2 di 2
    • Pull the tab and the lid will pop up.
  2. Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 2, immagine 1 di 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 2, immagine 2 di 2
    • Grab the lid and pull it up and off.
  3. Dell Optiplex 745 Small Form Factor Audio Components Replacement, Front Audio Panel: passo 3, immagine 1 di 1
    • Disconnect the cable attached to the audio panel by gently pulling the head of the cable away from the port.
    • When creating this guide a cable was absent, in the picture you will find where that cable would be connected.
  4. Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #2 screw driver, unscrew the 9.5 mm screw that holds the audio panel in place.
  5. Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 5, immagine 1 di 2 Dell Optiplex 745 Small Form Factor Audio Components Replacement: passo 5, immagine 2 di 2
    • Carefully grasp the audio panel from the sides, pull it back and out of it's slot.
Conclusione
USF Tampa, Team S5-G5, Walkup Fall 2017 Membro di USF Tampa, Team S5-G5, Walkup Fall 2017
USFT-WALKUP-F17S5G5
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,132
