Parti
Nessuna parte specificata.
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Disconnect the ATX power cable to the motherboard.
Disconnect the P4 12V(4x2) power cable from the motherboard.
With the motherboard out of the tray, let your soldering gear warm up and get a desoldering braid.
Desoldering can damage motherboards, so first practice on a board you don't need. Use a 40-50W soldering iron with a chisel tip and 0.080" wide desoldering braid. Also helpful are rosin flux and 60/40 tin/lead solder, in case all the solder doesn't come out. Wiggle desoldered leads to verify they're free, and never pull on any that aren't.
Altre 3 persone hanno completato questa guida.
