Salta al contenuto principale
Dell OptiPlex GX260 Optical Drive Replacement
Cosa ti serve
  1. Dell OptiPlex GX260 Optical Drive Replacement, Case: passo 1, immagine 1 di 2 Dell OptiPlex GX260 Optical Drive Replacement, Case: passo 1, immagine 2 di 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: passo 2, immagine 1 di 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: passo 2, immagine 2 di 3 Dell OptiPlex GX260 Optical Drive Replacement, Optical Drive: passo 2, immagine 3 di 3
    • Identify the optical drive in the case.
    • Remove the analog audio cable from the optical drive.
    • Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
    • Remove the power cable from the optical drive.
  3. Dell OptiPlex GX260 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Push the two green tabs toward each other to release the optical drive and lift it out.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 4-48, Amido Fall 2010 Membro di Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 8,950
