Strumenti
Parti
Nessuna parte specificata.
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
Disconnect the ATX power cable to the motherboard.
Disconnect the P4 12V(4x2) power cable from the motherboard.
Altre 15 persone hanno completato questa guida.
3 Commenti
Mines stuck for some reason I almost bent the frame from pushing the ports in while lifting and pulling the tray tab away
make sure you doing it the correct side!
muy bueno gracias bro
