Salta al contenuto principale
Dell OptiPlex GX260 Hard Drive Replacement
Cosa ti serve
  1. Dell OptiPlex GX260 Hard Drive Replacement, Case: passo 1, immagine 1 di 2 Dell OptiPlex GX260 Hard Drive Replacement, Case: passo 1, immagine 2 di 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: passo 2, immagine 2 di 3 Dell OptiPlex GX260 Hard Drive Replacement, Hard Drive: passo 2, immagine 3 di 3
    • Identify the Hard Drive in the case.
    • If there is more than one hard drive installed the process is the same for each hard drive.
    • Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
    • Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
  3. Dell OptiPlex GX260 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pinch the two green tabs inwards to release the hard drive and lift it out.
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team 4-48, Amido Fall 2010 Membro di Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Membri
27 Guide realizzate
Un commento
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
Elvis 1357 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 18,733
