Salta al contenuto principale
Dell OptiPlex GX260 Case Replacement
Cosa ti serve
  1. Dell OptiPlex GX260 Case Replacement, Case: passo 1, immagine 1 di 2 Dell OptiPlex GX260 Case Replacement, Case: passo 1, immagine 2 di 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
Conclusione
To close the case, simply press it closed until you hear the tabs click into place.
Altre 18 persone hanno completato questa guida.
Cal Poly, Team 4-48, Amido Fall 2010 Membro di Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Membri
27 Guide realizzate
Un commento
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 18,744
