Introduzione
This guide was created for people who may need to replace the RAM for the Dell Optiplex FX 170. Someone may need to replace this component if it isn't working properly or has failed. This is an easy fix with no hazards. One should be familiar with electro-static discharge.
Parti
Nessuna parte richiesta.
With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
  • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
  • Pull the base stand straight up from the device.
Aggiungi Commento
Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
Aggiungi Commento
  • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
  • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
Aggiungi Commento
  • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
Aggiungi Commento
  • Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
Aggiungi Commento
  • Lift and pull out the RAM.
Is it possible to increase memory, maybe about 8 RAM? Have you try to install Debian Linux?
Vic - Replica
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 707
