Salta al contenuto principale
Dell OptiPlex FX170 Memory Board Replacement
Cosa ti serve
  1. Dell OptiPlex FX170 Memory Board Replacement, Case: passo 1, immagine 1 di 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
  2. Dell OptiPlex FX170 Memory Board Replacement: passo 2, immagine 1 di 2 Dell OptiPlex FX170 Memory Board Replacement: passo 2, immagine 2 di 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
  3. Dell OptiPlex FX170 Memory Board Replacement: passo 3, immagine 1 di 3 Dell OptiPlex FX170 Memory Board Replacement: passo 3, immagine 2 di 3 Dell OptiPlex FX170 Memory Board Replacement: passo 3, immagine 3 di 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
  4. Dell OptiPlex FX170 Memory Board Replacement: passo 4, immagine 1 di 2 Dell OptiPlex FX170 Memory Board Replacement: passo 4, immagine 2 di 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
  5. Dell OptiPlex FX170 Memory Board Replacement, Memory Board: passo 5, immagine 1 di 1
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,492
