Introduzione
You should be familiar with the basics of taking apart a computer take apart, specifically in terms of preventing further damage due to electro-static discharge (ESD).
Cosa ti serve
With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
Pull the base stand straight up from the device.
Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
To remove the battery, pull up on the connector that is plugged into the motherboard.
