Salta al contenuto principale
Dell Latitude X300 Cooling Fan Replacement
Cosa ti serve
  1. Dell Latitude X300 Cooling Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Dell Latitude X300 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Slide the battery out of the laptop.
  3. Dell Latitude X300 Cooling Fan Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  4. Dell Latitude X300 Cooling Fan Replacement: passo 4, immagine 1 di 2 Dell Latitude X300 Cooling Fan Replacement: passo 4, immagine 2 di 2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. Dell Latitude X300 Cooling Fan Replacement: passo 5, immagine 1 di 1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Dell Latitude X300 Cooling Fan Replacement: passo 6, immagine 1 di 1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  7. Dell Latitude X300 Cooling Fan Replacement: passo 7, immagine 1 di 1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  8. Dell Latitude X300 Cooling Fan Replacement, Palm Rest/Track Pad: passo 8, immagine 1 di 1
    • Position the laptop so that the bottom is facing upward.
    • Remove the three 4 mm Phillips #0 screws holding the bottom of the palm rest.
  9. Dell Latitude X300 Cooling Fan Replacement: passo 9, immagine 1 di 1
    • Return the laptop to proper position and open the screen.
    • Remove the six 4 mm Phillips #0 screws holding in the palm rest.
  10. Dell Latitude X300 Cooling Fan Replacement: passo 10, immagine 1 di 1
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  11. Dell Latitude X300 Cooling Fan Replacement: passo 11, immagine 1 di 1
    • Lift up on the small ZIF connector and remove the ribbon.
    • If the ribbon seems stuck, gently wiggle it to remove. Do not pull the ribbon with great force.
  12. Dell Latitude X300 Cooling Fan Replacement, Cooling Fan: passo 12, immagine 1 di 1
    • Remove the four 3 mm screws that hold the cooling fan to the system board.
  13. Dell Latitude X300 Cooling Fan Replacement: passo 13, immagine 1 di 1
    • Remove the tape holding the cooling fan wires down.
  14. Dell Latitude X300 Cooling Fan Replacement: passo 14, immagine 1 di 1
    • Unplug the cooling fan wires from the system board by gently pulling on the hard molded plastic portion.
    • Be careful not to damage the wires by tugging on them.
  15. Dell Latitude X300 Cooling Fan Replacement: passo 15, immagine 1 di 1
    • Lift the cooling fan out of the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 11-20, Maness Winter 2012 Membro di Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,435
