Introduzione
If your device is still not working you may need to replace the motherboard. This replacement guide walks you through each step of how to safely remove and replace your Dell Latitude ST motherboard.
Cosa ti serve
Remove the 3mm Phillips #0 screw from the SSD drive which is located above the speaker and to the left of the motherboard.
Altre 4 persone hanno completato questa guida.
