Introduzione
If the camera application on your Dell latitude ST is not working you may need to reboot the system. If the reboot does not solve the issue try performing a factory reset. If your camera is still not working you will need to replace the camera on the device. This guide goes through each step to show you how to replace the camera on your Dell Latitude ST.
Cosa ti serve
Pull up on the copper antenna tape to loosen it from the base.
Unscrew the seven 6mm Phillips #0 screws from the base.
Unplug the white camera cord located on the right side of the middle frame under the WLAN card.
Using your hands, or the blue plastic opening tool, pull the white part of the cable to the right to disconnect it.
