Salta al contenuto principale
Dell Latitude E7470 Fan and Heatsink Replacement
Cosa ti serve
  1. Dell Latitude E7470 Fan and Heatsink Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
  2. Dell Latitude E7470 Fan and Heatsink Replacement, Battery: passo 2, immagine 1 di 1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Fan and Heatsink Replacement: passo 3, immagine 1 di 2 Dell Latitude E7470 Fan and Heatsink Replacement: passo 3, immagine 2 di 2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Fan and Heatsink Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: passo 5, immagine 1 di 2 Dell Latitude E7470 Fan and Heatsink Replacement, Fan and Heatsink: passo 5, immagine 2 di 2
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Fan and Heatsink Replacement: passo 6, immagine 1 di 1
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,682
