Salta al contenuto principale
Dell Latitude E7440 Hard Drive Replacement
Cosa ti serve
  1. Dell Latitude E7440 Hard Drive Replacement, Prepare the laptop: passo 1, immagine 1 di 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Replacement, Release the battery: passo 2, immagine 1 di 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: passo 2, immagine 2 di 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: passo 2, immagine 3 di 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Replacement, Remove the battery: passo 3, immagine 1 di 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
    • Slide the service tray using the middle stand offs to then be able to lift the tray off.
  5. Dell Latitude E7440 Hard Drive Replacement: passo 5, immagine 1 di 2 Dell Latitude E7440 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove four M2 x 3mm Phillips #0 screws from the hard drive cage.
    • Remove the hard drive cage by lifting it off the laptop.
    • The hard drive cage is not pictured here, but the screws will be in these locations.
  6. Dell Latitude E7440 Hard Drive Replacement: passo 6, immagine 1 di 2 Dell Latitude E7440 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Disconnect the hard drive connector from the top of the drive.
    • iFixit's device came without a hard drive to picture. Your device will have a component connected to the thin, black connector.
    • The hard drive connector can be removed from the laptop body to make replacement easier.
Conclusione
Altre 4 persone hanno completato questa guida.
Akash Kedia
Membro da: 01/24/19
1.445 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G5, White Winter 2019 Membro di Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Membri
5 Guide realizzate
3 Commenti
Hi, my problem is the opposite, I have an hard drive but seems like my HDD connector doesn't plug in the small port. I can send you a pic, I need help
†Winterfall† - Replica
I want to use a Seagate hard disk, but when I start it, it demands me a password. Can you help me in this case please?
Aldoni JB - Replica
It sounds like your BIOS is locked to only work with that hard drive
Magnus Vacuum -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 78
Tutti i Tempi: 12,148
