Salta al contenuto principale
Dell Latitude E7440 Battery Replacement
Cosa ti serve
  1. Dell Latitude E7440 Battery Replacement, Prepare the laptop: passo 1, immagine 1 di 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Battery Replacement, Release the battery: passo 2, immagine 1 di 3 Dell Latitude E7440 Battery Replacement, Release the battery: passo 2, immagine 2 di 3 Dell Latitude E7440 Battery Replacement, Release the battery: passo 2, immagine 3 di 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Battery Replacement, Remove the battery: passo 3, immagine 1 di 1
    • Lift the battery by the top, away from the laptop body.
Conclusione
Altre 9 persone hanno completato questa guida.
Akash Kedia
Membro da: 01/24/19
1.445 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G5, White Winter 2019 Membro di Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Membri
5 Guide realizzate
2 Commenti
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Anwar Ben Tanfous - Replica
Any recommended site to buy original battery?
Razin Ahmed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 76
Tutti i Tempi: 5,818
