Salta al contenuto principale
Dell Latitude E7270 Solid State Drive Replacement
Cosa ti serve
  1. Dell Latitude E7270 Solid State Drive Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Solid State Drive Replacement: passo 2, immagine 1 di 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Solid State Drive Replacement: passo 3, immagine 1 di 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Solid State Drive Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Solid State Drive Replacement: passo 5, immagine 1 di 2 Dell Latitude E7270 Solid State Drive Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Solid State Drive Replacement: passo 6, immagine 1 di 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Solid State Drive Replacement, Solid State Drive: passo 7, immagine 1 di 1
    • Locate the SSD stick on the bottom right of the device.
    • In the absence of an SSD, a RAM stick was used as a substitute for visual and educational purposes only. The SSD in your device will resemble a RAM stick but may differ in color.
  8. Dell Latitude E7270 Solid State Drive Replacement: passo 8, immagine 1 di 1
    • Slide the SSD of its socket.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thumbs down for showing a memory module and not a SSD.
Christopher Gehringer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 57
Tutti i Tempi: 4,447
