Introduzione
Use this guide to replace a broken motherboard on your Dell Latitude E7270.
The motherboard is what links all your components together to move information around. They are susceptible to age, shortages, and physical damage. A broken motherboard may leave your computer not working at all.
Before using this guide, check out the troubleshooting page to see if your symptoms match any that represent a bad motherboard.
This replacement requires a #00 Phillips head screwdriver.
NOTE: This guide requires removal of the back panel, battery, and cooling fan. The extra prerequisite guide steps are included in this guide.
Cosa ti serve
Place the device top down in front of you so that the vents are visible and are furthest from the user.
Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
Remove the 10 wire connections by using your fingers to separate the connections.
Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
