Salta al contenuto principale
Dell Latitude E7270 Fan Replacement
Cosa ti serve
  1. Dell Latitude E7270 Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Fan Replacement: passo 2, immagine 1 di 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Fan Replacement: passo 3, immagine 1 di 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Fan Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Fan Replacement: passo 5, immagine 1 di 2 Dell Latitude E7270 Fan Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Fan Replacement: passo 6, immagine 1 di 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Fan Replacement, Cooling Fan: passo 7, immagine 1 di 3 Dell Latitude E7270 Fan Replacement, Cooling Fan: passo 7, immagine 2 di 3 Dell Latitude E7270 Fan Replacement, Cooling Fan: passo 7, immagine 3 di 3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Fan Replacement: passo 8, immagine 1 di 1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Fan Replacement: passo 9, immagine 1 di 1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,398
