Salta al contenuto principale
Dell Latitude E7270 Battery Replacement
Cosa ti serve
  1. Dell Latitude E7270 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Battery Replacement: passo 2, immagine 1 di 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Battery Replacement: passo 3, immagine 1 di 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
On Step 4 there is no screw on middle since that hole is for backpanel center screw.
Mikko Kuusio - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 72
Tutti i Tempi: 3,475
