Salta al contenuto principale
Dell Latitude E7250 SSD Replacement
Cosa ti serve
  1. Dell Latitude E7250 SSD Replacement, Battery: passo 1, immagine 1 di 2 Dell Latitude E7250 SSD Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 SSD Replacement, SSD: passo 2, immagine 1 di 3 Dell Latitude E7250 SSD Replacement, SSD: passo 2, immagine 2 di 3 Dell Latitude E7250 SSD Replacement, SSD: passo 2, immagine 3 di 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 SSD Replacement: passo 3, immagine 1 di 3 Dell Latitude E7250 SSD Replacement: passo 3, immagine 2 di 3 Dell Latitude E7250 SSD Replacement: passo 3, immagine 3 di 3
    • Locate your SSD, it is on the right side and held in with a small screw.
    • Unscrew the SSD carefully. Once done, the SSD will "pop" upwards at an angle making removal easy.
    • Gently grasp the SSD on either side with your thumb and forefinger and pull away from the computer.
Conclusione
Altre 7 persone hanno completato questa guida.
Un commento
Thanks a lot for this !
viperx007 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 144
Tutti i Tempi: 10,831
