Salta al contenuto principale
Dell Latitude E7250 RAM Replacement
Cosa ti serve
  1. Dell Latitude E7250 RAM Replacement, Battery: passo 1, immagine 1 di 2 Dell Latitude E7250 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: passo 2, immagine 1 di 3 Dell Latitude E7250 RAM Replacement, RAM: passo 2, immagine 2 di 3 Dell Latitude E7250 RAM Replacement, RAM: passo 2, immagine 3 di 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: passo 3, immagine 1 di 3 Dell Latitude E7250 RAM Replacement: passo 3, immagine 2 di 3 Dell Latitude E7250 RAM Replacement: passo 3, immagine 3 di 3
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 51
Tutti i Tempi: 4,866
