Salta al contenuto principale
Dell Latitude E6530 Battery Replacement
  1. Dell Latitude E6530 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the computer over so that the bottom panel is facing you.
  2. Dell Latitude E6530 Battery Replacement: passo 2, immagine 1 di 2 Dell Latitude E6530 Battery Replacement: passo 2, immagine 2 di 2
    • Slide the switches away from each other to release the battery.
  3. Dell Latitude E6530 Battery Replacement: passo 3, immagine 1 di 2 Dell Latitude E6530 Battery Replacement: passo 3, immagine 2 di 2
    • Using your hands, gently remove the battery from the device.
Conclusione
To reassemble your device, follow these instructions in reverse order. If issues arise after replacing the battery, refer to the troubleshooting page or additional links for more help.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 26
Tutti i Tempi: 872
