Salta al contenuto principale
Dell Latitude E6420 Wireless Card Replacement
Cosa ti serve
  1. Dell Latitude E6420 Wireless Card Replacement, Battery: passo 1, immagine 1 di 2 Dell Latitude E6420 Wireless Card Replacement, Battery: passo 1, immagine 2 di 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Wireless Card Replacement: passo 2, immagine 1 di 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: passo 3, immagine 1 di 2 Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: passo 3, immagine 2 di 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Wireless Card Replacement: passo 4, immagine 1 di 2 Dell Latitude E6420 Wireless Card Replacement: passo 4, immagine 2 di 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Wireless Card Replacement, Backplate: passo 5, immagine 1 di 2 Dell Latitude E6420 Wireless Card Replacement, Backplate: passo 5, immagine 2 di 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Wireless Card Replacement: passo 6, immagine 1 di 2 Dell Latitude E6420 Wireless Card Replacement: passo 6, immagine 2 di 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Wireless Card Replacement, Wireless Card: passo 7, immagine 1 di 2 Dell Latitude E6420 Wireless Card Replacement, Wireless Card: passo 7, immagine 2 di 2
    • Using the screwdriver, remove two 4mm JIS #0 screws.
  8. Dell Latitude E6420 Wireless Card Replacement: passo 8, immagine 1 di 3 Dell Latitude E6420 Wireless Card Replacement: passo 8, immagine 2 di 3 Dell Latitude E6420 Wireless Card Replacement: passo 8, immagine 3 di 3
    • Disconnect 4 wires by pulling upward.
    • Gently remove the wires to prevent damaging them.
  9. Dell Latitude E6420 Wireless Card Replacement: passo 9, immagine 1 di 1
    • Lift the wiring harness out of the way.
  10. Dell Latitude E6420 Wireless Card Replacement: passo 10, immagine 1 di 3 Dell Latitude E6420 Wireless Card Replacement: passo 10, immagine 2 di 3 Dell Latitude E6420 Wireless Card Replacement: passo 10, immagine 3 di 3
    • The card will lift up, remove the card by pulling the lifted edge away from you.
Conclusione
Altre 2 persone hanno completato questa guida.
Madysen Eames
Membro da: 02/27/18
1.555 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,248
